cheaper to use cat5
Balun at each end for each cam and DVR connection, if lucky you could get away with one single run. That would be lucky though.
Playing devils advocate though, you could technically be in breach of DPA. Reason being, 3 cams would not be on property of the owner of the DVR.[/quote]
Can you advise on DPA and Balun?
I would only be looking at using 2 cameras running back to the recorder, the other houses are across the Close
