Hey,
I'm after a bit of advice on this project.
My garage is 3.5x10m and runs the length of the house, currently it has a flat roof that I have been patching up forever, the time has come to re-roof and I would rather change to a lean to pitched type roof rather than just replace with another felt/fibreglass roof.
The wall construction is solid brick, two skins on proper foundations.
I was going to use Marley Thrutone composite slate (600x300) laid at somewhere around 15-17 degrees.
Where I want some advice is on the timber sizes to be using. Looking at span charts I have come up with the following.
Rafters - C16 47x150 (span 3.55m @ 17 degrees, 400 centres)
Ceiling Joists - C16 47x150 (span 3.35m, 400 centres)
What should I be using for Joist and Rafter plates, I assume I am right @ 47x100 C16 for the wall plate.
I've added a photo, if anyone has any suggestions or notice any potential pitfalls that would be great.
