Sorry in advance if this is a long and confusing thread.
So we have recently bought our first home and are looking at building a garage around 4.25m wide by 7m long which would end up just under 30m square.
Im just looking for some advice or info people could give that may help as im not sure what to do next. I have looked on the planning portal website and there are a few conditions which my garage plans will not meet if i was to do it how id like.
Planning Permission
- Maximum height of 2.5 metres in the case of a building, enclosure or container within two metres of a boundary of the curtilage of the dwellinghouse.
Ideally i would be having a dual pitched roof with an overall height of around 3.5m. This would be permitted if i was building the garage more than 2 metres from the boundary, but id want it as close as possible to the boundary, ideally less than a metre but looks as though it would make getting plans easier if it was at least a metre away?
Building Regulations
- If the floor area of the building is between 15 square metres and 30 square metres, you will not normally be required to apply for building regulations approval providing that the building contains NO sleeping accommodation and is either at least one metre from any boundary or it is constructed of substantially non-combustible materials.
So does this mean if i am less than 30 metres squared floor area and built from substantially non-combustible materials (brick walls and tiled roof) that i would be allowed to build LESS than 1 metre from the boundary? Just with it saying 'and is either at least one metre from any boundary or it is constructed of substantially non-combustible materials'
So here is the plot where the garage is going to go
Cleared the decking and roughed out a garage shape with where i would ideally have it (under 1 metre from boundary)
So heres a pic as it is
and a sketch of how id like it from the same view (although this is with it 1m from the boundary)
You may also be able to see from the pictures that the garden is on a slight slope up towards the back of the garden. At a guess id say id need to dig the back out 50cm to get the garden level, would this be a problem for water seeping into the garage from the neighbours gardens?
So from all this what advice could people give and what would i be looking at doing next, is there a way of not needing planning permission or building regs without having a flat roof?
Any help would be great and sorry again if this is long winded.
Planning Permission
