Advice on upgrading insulation of vaulted ceiling
10 Sep 2008
Hertfordshire
I have a vaulted ceiling in two of the bedrooms of my bungalow. When rebuilt in around 2000 the spec was for 125mm rafters and 75mm celotex cut between the rafters with a pvc vapour barrier stapled to the rafters and then overboarded with 12mm plasterboard as below.
I have two aims. Firstly to get rid of the artex and secondly to increase the insulation of the ceiling. Can I attach foam backed plasterboard directly over the exuting plasterboard and skim or should I put 50 x 50mm battens secured to the existing rafters and then cut 50mm celotex between them with a new 12.5mm plasterboard and skim ceiling. with the existing vapour barrier in place is this trapping moisture in the new battens and insulation? Alternatively do I need to remove the existing plasterboard and vapour barrier and plant battens directly on the rafters and then add additional insulation? Any advice would be appreciated.
View attachment 369370 View attachment 369369
Add more underneath. No need for battens. We do it a separates rather than inso' backed boards. Much easier and you can stagger the joins and foil tape the joints and use Duplex boards.
Thanks @noseall . What do you mean by separates rather than inso" backed boards?
I assume you mean Gyproc Duplex which has foil backing but where does the extra insulation figure?
Many thanks
Many thanks
Separates as in sheets of foil PIR insulation and sheets of foil backed plasterboard - rather than insulated plasterboard. I hate the stuff.
Ahh so you would mechanically fix or glue the insulation first then overboard with Duplex using long screws through both?
Get the proper washers, don't put screws in at an angle!
