- Joined
- 9 Apr 2015
- Messages
- 36
- Reaction score
- 0
- Country
On the ground floor of our 1980s ex-council terraced house, we had quite a bit of damp/water damage to the wall from the bay window ceiling to the window sill.
We also had what looked like damp/water damage coming from the ground between the bay window and the main entrance to the house. This would be the lounge and part of the downstairs hallway.
See the pictures for the internal damage
In August 2024, I contacted a general builder company, who identified that the water was coming in from the corner of the roof bay window, and travelling down the bay window wall, and then following cracks in the wall across towards the main entrance.
They are highly rated on Google/Facebook, and a friend of a friend recommended them.
The builder quoted £2600 to:
- source a roofer to install a new fibre glass roof.
- install new roof facia and guttering.
- rake out and repoint brickwork.
- seal up vulnerable areas with sealant.
- Internally seal any weak points, fill and sand using interior filler over cracks.
I then waited until October for their roofer to become available. After admitting that they had no idea when he'd be available, I asked if they'd be fine for me source a roofer and for them to re-quote, minus the roofing parts.
I also sent them some new pictures of the internal wall damage.
They replied saying that the internal wall will now need replastering / skimming due to the damage and quoted £1968 for:
- prep internal walls for skimming.
- reskim water damaged walls.
So I organised a roofer, who I had used before, to do the following early December 2024, for £1550:
- Ladder work used.
- Cleaned the area above the front bay window and made ready for roof works.
- Supplied and fitted a 4x2 treated timber and fixed to the front and sides of the roof to extend. Removed the rear flashing and disposed of.
- Supplied and fitted OSB3 boards to the base of the roof and screwed and fixed in place. Supplied and fixed GRP trims to the roof ready for the fibreglass.
- Supplied and wet the boards with resin, applied CSM glass and worked into the resin. Allowed setting time.
- Once dry sanded the base coat.
- Supplied and laid a topcoat, covering the whole roof and allowed curing time.
- Supplied and fitted a new flashing to the rear wall and fitted in place to seal, pointed the open joint with a sealant.
The builders (2 of them) then came on Monday 6 January 2025. They said that the internal wall didn't need replastering / skimming. They can fill and sand it instead.
They were here for no more than 2 hours on Monday, Tuesday, Thursday, Friday, and Saturday. Totalling no more than 10 hours (always between 9:30 and 12:00).
They are coming one final time on Wednesday, to make sure all looks okay and is dry, and the internal walls are flat enough to paint on.
I mentioned that, as they didn't have to replaster/skim, could they resend the quote. They then said we'd only be saving on the skimming materials, as the time to fill and sand would be the same.
Only a small section of the bricks on the outside wall were raked out and repointed.
Also they said the section in the downstairs hallway didn't need to be treated.
I don't have anyone I can check this with, and I feel that £1968 for 10 hours work (and possibly another hour on Wednesday) is a lot of money.
Especially as they were £2600 with the roof fix, which ended up costing me £1550 with a trusted roofer.
I attach all before photos, followed by the completed repointed/sealed exterior brickwork and filled in/sanded interior walls (and the part in the hallway they said doesn't need treating).
Thank you for reading this. All advice welcome. Even if you think this is good value and that I am over-reacting.
The last 4 photos are of the finished areas.
- Ladder work used.
