No , the machine is not air tight but there is enough cold metal on the top of the drum and plastic fill corridor to condense the tiny amounts of moisture produced. A boil wash is rare these day and is not actually boiling .
Have our washing machine in a unheated utility room for last 20years without any condensation problems.
I coated the frame in Cuprinol, followed by some anti-damp/mould resistant paint around the base, so the frame should be pretty well protected. Bottom 2-3 layers of brick have also been coated with the anti-damp & mould resistant paint too.
Now for the ‘floor’, I’m wondering what to protect this with? It’s about 8mm plywood.
..show the frame in place, one side of the floor laid down, and there is to be a divider in the middle to frame the washing machine, with another section of floor to go on the opposite side. Should I paint the floors with the same anti damp anti mould paint? Cuprinol before or after? Spray-on polyurethane ? Something else? Once the floors are protected I’m thinking about adding a lip around the back & sides, silicon all edges (including of the ply) and then a section of rubber or anti-slip mat on top, under the machine itself.
