Circulation pump or control circuit faulty.
Run in diagnostics. Position 8
How to enter diagnostic mode on Electrolux EWF14742 time manager washing machine: 1. Turn the dial from off position to the 1st position clock-wise. 2. Once the machine powers up, simultaneously press and hold start/pause button and the option button above it until lights randomly start to flash. 3. Turn the dial to 2nd position clock-wise to test the wash inlet valve. 4. 3rd position will activate the pre-wash water valve. 5. 4th position activates both the wash and pre-wash valves. 6. 5th position activates 3rd solenoid valve (only some machines have this valve). 7. 6th position activates hot inlet valve (only some models have this feature) 8. 7th position tests the heating element. Water will fill above the heater element. Heating element and re-circulation pump will be activated. Water temperature will be displayed on the screen. 9. 8th position will test the operation of the drum. Drum will turn at 50 RPM clockwise and then 250 RPM counter clockwise. 10. 9th position will drain all water from the drum and will test the spin cycle, drum speed will be displayed on the screen. 11. 10th position is only for washer/dryer machines. 12. 11th position will display the last error code stored in the memory of the machine.
Not 100% sure this will work on your model but worth a try.
