I recently purchased a new air compressor via eBay from germany.
Its a 2HP 24 Litre compressor.
the only thing is, it didn't come with operating instructions - just maintenance instructions.
I turned it on for the first time tonight to test it - and I have the following quesitons:
1. It says on the bottle of oil I received with it that I should put oil in before starting the motor. There is a small window on the compressor with a red dot in the middle of it. I poured oil in until the window was half full. Should I have filled the window completely?
2. There is a smallred on-off button (push to make, pull to break jobby) and 2 guages. When I turned it on, both guages started increasing towards the red-line section so I turned it off. Should it turn itself off when it is 'full'?
3. Can they be used when they are on, or do I have to turn them on, fill the cylinder and then use the air tool?
4. The smaller of the two gauges, nearest the outlet - has a red 'turning' thing that has a + and - on it above the small guage - anyone know what this might be for?
thanks for any help...
Matt
Matt
