air lock in a bungalow
16 May 2012
Lancashire
Hi
I just swapped a rad for a towel rad in a bungalow for a friend, I had to drain the system to do this.
Now i seem to have a air lock so i need to refill i guess unless any workarounds
all rad pipes drop from ceiling the hot water cylinder is on the ground floor the header tank is in the loft whats the best way to refill?
thanks
Thanks nige
I drained refilled but was still a air lock so backfilled from drain off above bolier all fine now
hertsdrainage if nothing worthwhile say you might as well keep it stum or you wanting get you post count up
Set of Mugs- what does 'i guess unless any workarounds' mean???
You then answered your own question!!!
:rolleyes:
