The disaster happened this weekend, twisted the air separator while fitting a new pump.
It's not leaking and I have not fired up the system, not sure if I should leave it as is or replace it.
The top pipe is the feed from the FE tank - there is no vent to the FE tank, so why is the air separator needed? Could it not just be cut out and a 22mm T joint be fitted? If so would an air separator need to be fitted on the flow pipe from the boiler (eg a Spirotech deaerator)?
