I've always found stitching any cracks with tie wraps very effective.
Put the brush back into the glue immediately after applying and the brush won't go hard. After you have glued the joint you can push a piece of Baco foil down over the brush handle to prevent evaporation. If the glue has a screw top lid you can drill a hole the same diameter of the brush handle, slide it down over the brush handle and screw it tight, (leaving the foil seal in place). It won't stop it going hard indefinitely but you will save your brush going hard quickly.I might try a tiny paintbrush, but the solvent seems to dry very quickly, so I will end up with a heap of dried brushes.
Theoretically, with a good liquid solvent, you shouldn't get stuck together/dried out brushes - the bristles would only stick together if there was dissolved plastic remaining on the bristles.I might try a tiny paintbrush, but the solvent seems to dry very quickly, so I will end up with a heap of dried brushes.
A good swish around in the solvent after use, should dilute any remaining plastic and the brush can be wiped dry.
I've never found any harm using a soapy rinse afterwards as well.
Generally applied using a needle bottle, https://www.amazon.co.uk/Needle-Bottle-Applicator-Squeeze-Acrylic/dp/B08YNHTH1J
and for the best results it's not glue, but a solvent which welds the plastic together such as https://deluxematerials.co.uk/products/plastic-magic-1
