prob need to omit un used zones,either by programming or inserting links in the terminals,factory settings normally enable all zones,have you tried linking out all zones then setting the system?
RMS said:I know beezer but there is no door contacts, just 4 zones which are all pir's. If there was a problem with one of the zones then by linking out one zone at a time it should clear but it only does this when all zones are linked out.
ch427 said:put some links in zones 3 and 4 then try it,i seem to remember these being immediate zones on a factory programme
RMS said:Tried it and when setting the panel the beeps are not as fast but they dont stop.
Also, forgot to mention non of the pir's are flashing with movement.
