I have an Albion Mainsflow cylinder fitted for about three years and has recently developed a leak internally from the mains pressure coil int the static heatstore. I tried in vain to apply the warranty with the makers.
The fault allowed about five litres of water to be discharged through the overflow each day. It was not cost effective to replace the cylinder purely on the cost of the water lost and I therefore thought of a less costly solution.
I bought three components. A pressure switch which senses the drop in pressure as a tap is opened, a pilot operated solenoid valve and a non return (double check valve). The pressure switch is fitted on the hot water outlet along with the check valve. The solenoid valve is fitted to the mains cold supply to the coil.
The seepage to the overflow is reduced to a negligible
