I wish to install an Inverter Range split Room Air Conditioner. There are various sizes available,the smaller of which the instructions say can be plugged into the electrical supply via a 13Amp plug. The instructions state that the size of conditioner that I wish to install, 18k, requires a 20Amp Isolation switch capacity. The instructions state "An all-pole disconnection switch having a contact separation of at least 3mm in all poles should be connected in fixed wiring".
Taking a new cable back to the consumer unit would be very difficult and I had, therefore, proposed to take a spur off the ring main and install a 20Amp fused socket.
Questions:
1. Would this be safe and meet the wiring regulations?
2. Can anyone identify for me the required "all pole disconnection switch". I understand that I must not isolate the appliance earth and assume, therefore, that a 2 pole switch is all that is required. The electrical wholesaler that I tried was not able to help.
3. The ring main is protected by a main switch that is coded CD282U 80A and does not appear to be RCD protected, as these protected circuits are on the right side of the consumer unit whilst the ring main is on the left. That said the actual switch headed "RCD Controlled Circuits" seems to be identical to that referred to above i.e CD282U 80A. The cooker circuit is on the side of the unit labelled "RCD Controlled circuit". I provide this information as the spur would be off the ring main.
Any help would be much appreciated.
Questions:
