OK. However, I'm a bit confused as to how you can know for sure that it was a lamp blowing that caused the RCD to operate (which would have required you, or someone, to be present when the bulb blew and the RCD operated) without you (or someone) having immediately reset the RCD and therefore avoided any risk to your freezer contents. Was the situation perhaps a little more complicated than you have indicated?In my case it happened with an insulated lampholder on a standard ceiling rose. It was a couple of years ago with my cousin staying in the house too at the time. I nearly lost all of the food in my freezer as a result but noticed in time!
Kind Regards, John
