Hello, is there an alternative to a septic tank, something that doesnt need to be emptied once a year?
They are always septic.cause the Tank to turn septic
Might be worth looking at Klargester https://www.kingspan.com/gb/en/products/water-management/septic-tanks/alpha-septic-tanks/Hello, is there an alternative to a septic tank, something that doesnt need to be emptied once a year? we are having trouble getting our tank emptied, due to restricted access. thanks in advance, Mart
Operating correctly, they should keep a balance of healthy bacteria allowing the anaerobic breakdown of solid matter into sludge. If they go septic, the Bacteria are killed off, the tank ceases to function as it should and before long you have an unholy mess on your hands. This is why it is vital sludge is drawn off on a regular basis, frequency will depend on usage, to allow the bacteria levels to remain healthy.They are always septic.
The final effluent can be discharged to a watercourse, without further treatment. But, it depends on a few things.
Do you know it is a septic tank? Regardless of the definition of Septic, a septic tank relies on bacteria to break down the sewage and the watery residue then usually discharges into a soakaway, or as a last resort after further treatment into a watercourse. The tank does need occasionally to be emptied but you might manage a couple of years depending on volume and how big your family is. Alternatively you've got a cess pool. These are not designed to have an outlet like a septic tank but must be emptied when full.Hello, is there an alternative to a septic tank, something that doesnt need to be emptied once a year? we are having trouble getting our tank emptied, due to restricted access. thanks in advance, Mart
Often known as tertiary treatment (third) and used after the septic tank.There is such a thing as a reed bed system, but that is a pretty major undertaking...
My own tank is a little difficult to access but the firm I use have a large AWD tractor that manages no problem.Many thanks for the detailed replies, I will talk to Klargester. We have lost our turning space so tanker access is very difficult now, (Narrow / steep lane ) same issues with oil delivery. Thanks
