aluminum or stainless steel heat exchangers your views on pros & cons?
let the battle commence
how do boiler manu get away with using a corrosive part on a boiler!!
if its not fit to do the job why use it??
I know my isar has a ally one, thanks to idealboilers. Is stainy one available? thank you.
edit ta.
Indeed a stainless HE is available for an Ideal... Just replace the HE with one from a decent boiler and then fit the rest of the decent boiler leaving the Ideal on your front doorstep for the ****** to take away... They are the only folk who want an ideal these days..
Lets not forget guys that if the flux isn't flushed out of the heating system after installation then the water could well be corrosive to Stainless
I remember our Vaillant rep proudly extolling the virtues of their stainless steel heat exchangers, saying only fools would fit aluminium. After all, condensate dissolves them!
I had to point out that most of Vaillant's commercial condensers are made of aluminium.
My personal view is that I've seen plenty of disasters in both aluminium and stainless; it is the design and execution which makes most of the difference, not the material.
