Well, I, for one, found your research and conclusion interesting.
You sound a bit like me insofar as you like to know what's what and you went out of your way to find out as best you could. I've done a bit of digging myself in order to find the most suitable solution when my current boiler gives up the ghost (assuming that one day it will) and you've suggested points that I wasn't aware of.
I hope it goes well for you and that you might return to advise how it went.
I thought Id return for some advice to dispel some myths that i am sure will help many in the same situation as mine. UnfortuNately there aint much useful information on how things work, so I hope this is going to be helpful for many. Before that, a disclaimer that I am by no means a gas engineer or an expert and this is from whatever information I gathered during installation of my boiler.
i got a 25kW Ecofit Pure Heat only boiler in the end. For those interested to know why not an Ecotec Plus, please read my previous post above.
1) There is a lot of misinformation on gas pipes and boiler types. Basically, the gas supply at your meter has to be a minimum of 19 mbars and a max of 23 mbars which is the minimum and maximum supply requirement every house should be given. The requirement is a maximum of 1mbar drop of pressure at the boiler for it to be approved and signed off by the engineer. If there is a significant drop (>1mbar) of the pressure at your boiler, the engineer cannot approve it and your extended 10 year warranty will not be activated. So if the gas pressure is 20mbar at the meter, it has to be 19 mbar at the boiler. My gas pipe was hidden and there is no way to find out if it was 15, 22 or 28mm within the structure. The only way to find out was to test it after installation. My pressure at the gas meter was 19.4, at the boiler was 16.4. A significant drop of 3mbar meant i am having to get a new gas pipe installed around the structure of the house to be able to get the full 10 year boiler warranty.
2) Ive seen some believe that heat only boiler is more likely to pass a 15mm gas pipe test at higher wattage. Wrong. The engineer will test it at full 25kw if you have a 25kw boiler, at full 30kw if you have a 30kw boiler. Doesnt matter if you have a combi, system or heat only boiler, your wattage at which the boiler will be tested is the full wattage you purchase. As above, mine failed at 9-10m distance between the boiler and the gas meter. Probably, most of it in the structure is a 15mm gas pipe. I chose to run a 28mm gas pipe which is now going to go 19-20m around the house, a situation i wanted to avoid but i have no other option.
3) You should check the maximum wattage of your hot water cylinder and ensure you atleast have that wattage on your boiler to be able to heat your water at its full speed (which is hot water in 20 minutes at the advertised wattage). If your boiler has a lower wattage than on your cylinder, the cylinder isnt working at full capacity and it will take longer to heat water. One way to manage this would be to time your hot water 1 hour before your heating goes off in the morning and evening. I have a 300 litre megaflo with a wattage specified at 24.5kw. One can argue going lower than that on the boiler is acceptable and i agree it is, if you are happy to work your cylinder at lower than its maximum capacity. Bear in mind that if you have heating on simultaneous with hot water, your cylinder will only be able to extract only what the boiler is left with to deliver your cylinder. Also calculate some loss of heat as no system is 100% efficient.
4) Your boiler temperature and hot water cylinder temperature has to be set at an appropriate level, with boiler temperature higher than cylinder temperature, otherwise your boiler will never shut down in trying to get your cylinder water to a temperature it will never get to as youve kept your cylinder temperature higher than the boiler temperature. Ive kept my cylinder temp at 60C and boiler at 65C, and my hot water is timed (via a separate Drayton timer) to come for one hour in the morning and evening, before the heating kicks off depending on the temperature my Nest Learning thermostat is set at and outside temperature.
Hope this was helpful
