Agile said:
I think that you have wasted £53 ( plus all the transport costs )
Not sure about that! The journey was only 14 miles to pick it up and having a spare one ready in my view is not bad idea! So far, I'm now £3000 better off.
when all that is required is a little time to do the chemical treatment
I'm afraid some plumbers don't give out good advice like you
We find that this is very common with DIYers. They love to rush off at tangents and spend hours doing irrelevant things instead of following the simple professional advice!
I had 3 professional plumber advice/quote and 2 of them said my heat exchanger is causing the restricted flow to pump over to the F&E tank after 2 brand new boiler stat fitted. Would mean a new boiler because the heat exchanger is normally pitted(?), so I thought if I can find a heat exchanger at a reasonable cost, it's gamble, my choice considering the quote I had was from £2900 to £ 3700 for a Mexico boiler including power flush etc. After all that, it was a 3rd faulty boiler stat
Cost £12.85 and the pumping over to the F&E tank stopped immediately I put the new one in and after I bought the 2nd hand heat exchanger. I don't mind paying my hard dosh for a new boiler or whatever but only when it's necessary.
Have you got the gaskets to reassemble the HE?
These heat exchangers don't have gaskets, they have 8 x 'O' rings, which I have on standby with 12mm ceramic rope and rope glue.
Can you drill out and retap a bolt or stud if its snaps off?
No need, this heat exchanger is straight forward with stud bolt on the outside of the casing. If the stud bracket do snaps off, I'll get it welded
Oh yes, and of course changing the HE should only be done by a CORGI registered person. You have earlier implied that you did not want to do anything that you should not be touching!
Oh yes sir, that's correct. I stand by my words, I will not be touching it.
I'm still in love with my 26 yrs old boiler, she's a lovely model & I don't want to be unfaithful like 2 sh*gs
I don't like these PCB electronic stuff, maybe I getting old
