I've worked for the last 8 years as an awning installer, these are motorised so need a power supply ... some customers have light tracks & heaters (2kw halogen) fitted as well.
The wiring for these items all goes to a single RCD 13amp plug which i get to the nearest available 3 pin socket. ( if i fit two heaters then i need to use two plugs because the draw exceeds 13amps)
Any wiring that comes straight down the wall is encased in plastic 20mm round conduit.
Times move on & laws change ... Am i still legally going about my business?
