Heck, I'd have problems with that paper now.
... but I suspect that the same is probably true of the great majority of people who sit, and pass, the RAE today! However, as I've said, since home-brew is now pretty rare, I'm not at all sure that that really matters.
I would obviously have to familiarise myself with the current Licence Conditions in order to answer question (1) but, if I had done that, I'm reasonably confident that, if I had to take that exam today, I would probably pass, but maybe without getting the "distinction" which I seem to recall I got back in 1963!
If I were answering 'as I would have done back then', I would, today, probably have to pause briefly in order to give them circuit diagrams using valves, rather than transistors/ICs and I would almost certainly do question (5) rather than (10). In fact, the only two of those questions which I think I might struggle with a bit today (other than giving pretty general/vague answers) are the two about aerials/radiation [(7) & (10)] - which is a bit ironic, since that is one subject still of some relevance, even to those who buy off-the-shelf commercial rigs!
Questions (4) and (8) were obviously very simple (just calculations), and shouldn't really have taken me more than 'a couple of minutes' each - but it the other questions for which my 'not succinct' style (even back then) will have enabled me to waffle on for pages
I did about 18 months preparation for the exam. I was given a copy of the RSGB "Radio Communications Handbook" (600+pages) for my 12th birthday, and religiously went through all of it several times (and I also had a copy of the ARRL equivalent book).
I Have forgotten most of it and not used the rest of it - ...
I 'used' a lot of that knowledge back then, in relation to designing and building various bits of gear.
I gave up trying to use a radio due to the constant crud on the bands around me. 2m/70cm are dead around here, so my gear sits in a box somewhere.
As I've said, I gave up when (in addition to other 'life activities') it essentially ceased to be a technological hobby and really just turned into "CB", using commercial gear. After my initial (almost 'compulsory' back then!) few months of working on 'top band', nearly all of my activity was on 2m/70cm/23cm, including a fair bit of meteor scatter and moonbounce experimentation on 2m (for which I got a temporary 'high power' {1 kW} licence). A lot of my old gear (all home-brewed, apart from a rusting HRO) in still in my cellar gather dust, but hasn't been touched for decades, and very probably would not 'work' even if I wanted it to!
These days the above paper would be considered way too hard and not used, multiple choice questions would be and the answer should be clear. That's why we have so many idiots on the airwaves now
I'm sure you're right but, as above, doubt that there is a need for much 'technological knowledge' on the part of those using commercial gear.
Kind Regards, John
