I am installing fibre optics in a bedroom ceiling shortly. Will wire the light source and new light cable (for a new light switch) into the light circuit , using a 4 terminal 20 amp junction box. Am I right to assume that if the lightsource is 50 watts and the mains voltage is 250 volts , there will be 200 milliamps used and well below the 6 amp light circuit it will be wired into ? Also using t & earth 1.5mm cable .
Thanks for any help out there.
Barryg
Barryg
