Thank you to everyone for your answers, advice and concern.
Its unfortunate that i didn't discover this forum prior to starting my building project, however i am where i am, in that we have decided on Halogen downlights (which i know are hot) based on the desired look and low voltage was used due to the required lighting effect.
Cool fitting Halogens (which i know are still hot) are being used to reduce 25% of upward heat and using an ultra compact fire rated downlight. I accept that the Halogens aren't everyones choice, and thanks for the advice rather than critisism on my choice of lights.
I think i now have the answer to my initial question, although will start another topic in regards to calculating the wire thickness in regards to other applications.
As i understand it a 6amp MCB will be sufficient based on a 230/240 voltage supply (6x230 = 1380w)...the max watt will be 1350, but the halogen light i'm likely to use will be 40watts or less...therefore based on everyones comments i should be ok with a 6 amp MCB and 1.5mm cable.
Thanks for the info in regards to the switching and i can confirm that switches are 10amp (if i were to use a 10amp MCB), however the dimmers state 210 watts max on the transformer...this therefore raises another question in regards to having 7x50watt halogens on 1 dimmer?
Finally i accept its very unlikely that my house will be lit up light a christmas tree all the time, however some of you have mentioned "Diversity"...what is meant by this ?(i've had a guess but would welcome an exact answer)
I have assumed that the circuit should cater for all the lights being on at once (worst case), max power....is this wrong, and is this where diversity comes in?
Thanks again
