No. There is a separate FITS meter which records your generation. On small scale generation they use a percentage ratio to work out your export rather than install an import/export meter in place your old meter.There is a separate meter for export. AFAIK that is the norm.
You get paid for your generation wether you use it or export it, if you export it, you get a couple pence more. You’re better to use it though, and save on your import bill. Heat water for example.
