Angle Grinder arbor size
It can only be one of three things, the disc is out, the grinder is duff or you're fitting it wrong.
Am I correct that there is no 22mm vs 22.2mm discs, and all 230mm grinder discs should have the same bore?
I have the same grinder, and Hitachi and Bosch discs have always fitted without issue.
Duff disc I redkon!
