Angle Grinder Disc Removal?
14 Jan 2020
How do I remove/replace this grinder disc?
193814085288
you should have an allen key that fits into one of those 4 holes
then a lock mechanism on the grinder near the motor to stop the motor from turning, you just push that down
then turn the nut with the 4 holes in anticlockwise to undo
Thanks, what if I don't have one of those tools? Would the Allen key suffice? Also, I don't think there's a lock mechanism? Not one I can see anyway.
mine uses an allen key in the dewalt system , but i do remember the old cabled one i had did have a 2 pin spanner.
picture of the top and sides - they should be a little button , otherwise the motor will just turn when you try and do it up / un do
video of the dewalt with a allen type key to undo
It's off, thanks. A bit of oil and a couple of whacks and it was loose. Doesn't seem to be the safest of mechanisms for securing a rapidly spinning disc though?
No worries about that one, the direction of rotation ensures the round nut can’t unscrew.
I would however, clean all of the crap away from the vent slots so the tool doesn’t overheat.....
If you’re feeling really adventurous you could open the housing behind the disc for new grease.
John :)
Now you've got it off, if you intend to use it a bit it might be worthwhile getting an M14 quick lock nut - they don't require a pin spanner and are a lot easier to release (without needing any tools). I have a Bosch SDS one on my corded grinder which makes life a lot easier. Similar products can be had from Milwaukee, Metabo, Marcrist, etc. Prices are around £10 to £18 street price
Had never heard of these before, but always have a mare with my angle grinders when trying to change the disc - so have just ordered 2 of these from Amazon. Thanks :)
