Yeah.. once you have moved over to the quick release nut you will be wondering why you didn't buy one earlier.
Same here.I've not used a removal spanner for years. Hand tight only, and that's enough to just lock the spindle and rotate the disc by hand to remove it.
I've had a few disks explode, with the googles and guard on it was a none event really.
Anyone who goes near a grinder without proper eye protection is rolling the dice..
In over 50 years of using disc cutters/ grinders I can honestly say that ive not had a disc over 1mm thick break in use.. broke more of the latter by treading on grinder though.
Ive not seen or looked for anything that thin ,115mm disc ? I think .8mm is the thinnest ive usedWe use 0.5mm cutting disks and they don't like any kind of bending.
The point is, there is no need to torque the thing up to high heaven. Hand tight and then undo by hand. That will do for almost all usage. If it's too tight to undo, then use the spanner!That's great until you get a disc that seemingly welds itself in place
Always assuming you can find it.... I've had my fill of going to look for the pin spanner only to realise that I've left it in the workshop 50 miles away, or that I've brought the wrong one, or that the last guy using the grinder didn't return it to the box, etc, etc. The alternative is one of those nifty SDS nuts.....If it's too tight to undo, then use the spanner!
Must admit I've not had a disc break in use yet apart from when I've dropped the grinder on the floor, and I use a lot of them. Although I use a few less these days since I bought a reciprocating saw, you can cut a floor pan out in a fraction of the time and the blade is still good to go.In over 50 years of using disc cutters/ grinders I can honestly say that I've not had a disc over 1mm thick break in use.. broke more of the latter by treading on grinder though.
Or a hammer and a nail.The alternative is one of those nifty SDS nuts.....
