Angle grinder spindle locked up
4 Jul 2007
Derbyshire
I have a 9in Hitachi angle grinder. On changing a disc using the supplied tool located in the spindle holes, I find it is locked up.
I am turning it the right way, anticlockwise, but applying normal force (on the disc fitting tool) did not unlock it, so I tried tapping it with a nylon mallet. It is still locked solid, although the mating plate on the other side of the disc is turning with the spindle cap, whilst holding in the spring locking pin.
I have used this tool for many years, never having had a problem.
Any thoughts appreciated.
Lets get this right.....the machine isn't seized itself, its just the locking pin doesn't hold the arbor - is that correct?
If it is, the end of the locking pin has sheared off.
I've got round this by sacrificing the disc by holding it in a vice, and then using a centre punch and hammer to drift the collar loose.
John :)
If you have the model number Andrew, there are a few exploded diagrams on line - for example ToolPartsdirect.com
If you can find the part number, it can be found in the UK.
Its held in by a circlip and spring inside the geared driving head.
John :)
