Another Indesit problem
22 Apr 2008
Cheshire
Hi all,
Hope someone can help, I have a Indesit w123 and have had problems with it draining, had this problem before so I cleaned out the filter and the draw where you put the washing powder on and set it to do a full cycle. About half way through it decided to give up and the dial stated to just click through the cycles, I turned the machine of reset the dial and turn it back on as normal, it sounded like it took water into the washing draw and emptied it but its not just clicking again, anyone any ideas how to stop this from happening.
Thanks Phil
Dial clicking round just indicates there is a fault. Flashing light is flashing a code to you. Count the flashes between pauses and post the result here.
Its hard to count really, it flash's once for every 8 clicks of the dial if that is of any help.
Thanks again, Phil
