Hello all,
I was hoping for some advice please. I have spent a lot of time looking for the answer to this but with no luck.
I am trying to remove a downstairs thermalite wall between what was the back end of an integral garage and a small study next to it. The previous owner had a garage conversion done and the wall in question had an arch way put in to join the rooms. I want to take this out completely now.
I made some nice big holes in the ceiling and top of the wall to see what was up there and found things that indicate its probably not a supporting wall, like ...
It runs parallel to the floor joists above and there is no wall above it.
I took the arch completely out but left the concrete lintel in until I removed some of the highest blocks to see more. To one side I spotted a joist going the other way resting on the top of the blocks. It looks like its two joists joined together back to back and it runs through one of the parallel joists where its secured to it with fixing plates of some sort.
The double joist runs from just beyond the wall to be removed - but not up to the next joist and the other end I think goes into the kitchen and from what it looks like it sits on top of a dividing wall in the kitchen. Again there is no wall above this kitchen dividing wall. The kitchen wall is about 3ms long this joist on top of it runs for about another 2ms until it ends sitting on my suspect wall.
So, to summarize, it first looked like it was not a supporting wall but now it looks like something is siting on it but I still can't see exactly what it can be supporting bearing in mind all the above floors would be supported by the other parallel joists.
I know this is hard to visualize and if I get some people wanting more info I'll try and put some pics up.
I appreciate your advice,
Martin
Just added some pics....
Martin
