You can try and bait me with your insults but you're wasting your time.
So, the "professional" opinion is that despite the fact that the PCB has a facility whereby it offers flash codes to assist in diagnosis, it's quite normal for a fault in the fan to cause the PCB to simply play dead?
If you insist on using car analogies that's like saying that if you have a bulb failure then despite the fact that you've got a bulb failure monitoring system in the instrument cluster then it's acceptable for the battery to become automatically disconnected, thereby rendering all electronic diagnostic capability redundant and your car to be immobilised.
I see that the PCB has a socket at the front which looks like it might well be an access point for further electronic interrogation by a competent person with the correct diagnostic equipment. If that's the case then none of the three "professionals" that have looked at this boiler, and one of them is the bloke that installed it, had that equipment.
Imagine if your car had broken down and you called someone out to look at it. The first bloke that turned up was the bloke that sold you the car in the first place. He wants £100 call-out, turns up and says "Oh, that's weird. I don't know what's wrong with it." The second bloke turns up, also wants a call out charge, and tells me that the flue is installed incorrectly aas it's angled in such a way that the condensation will run back down the exhaust and re-enter the boiler............ he suggests that he cut a larger hole in my outside wall and angle the flue downwards so that the condensate runs OUTSIDE!
The third bloke I bumped into at a plumbers merchants. He seemed like he knew what he was doing and offered to come and take a look. he spent the day with me trying to point the blame at just about every possible component but not coming up with anything like sound reasoning and certainly no sign of any dignostic capability whatsoever. In the end I said to him "look, here's some cash, go and buy everything that could possibly be causing this boiler to be so unreliable and install it tomorrow whilst I'm at work. I'm fed up with spending my time poncing about with this thing when it could be better spent fixing cars and making money. Just make sure that when I get home from work tomorrow the house is warm." The next day i get home from work and there he is, reading the paper and drinking tea, with a pile of new unopened parts on the table next to him. "Why haven't you fitted these parts?" I exclaim.
""Because I wanted to wait for you to be here so you could help me" was his reply.
Given the experience that I've outlined, can any of you seriously question why I would not say "stuff this, I'm going to fix it myself!"?
So, don't get on your high horses, just do your bit to restore my failth in your profession and offer some positive, constructive advice please.
