Just bought a 1930's house and have had a quick check over the electrics.
Am intrigued because the supply comes into hallway from under the floor into a cast iron Y shape, with the phase & neutrals each going through a separate fuse wire (behind a cover - but not sealed) and then dissapearing into the wall to reappear further up at the meter. Never seen anything like it. Consumer unit is black with 6 blade wired fuses.
It's obviously been rewired at some point as there's grey pvc tc&e on the 2 upstairs and downstairs ring. Sockets are all skirting mounted. Lighting circuit goes through conduit and is individual cable. Most sockets and switches are in good condition if old. There's no equipotential bonding in the bathroom or kitchen (but there is to the gas and water supplies) but these are being replaced and will obviously be done as part of this.
The only thing that may signify the wiring's age is the green (not green & yellow) sheath on the earth - and maybe the 1977 paper I found under the boards!
Now - if it's all junk then it gets a rewire. But given that it looks OK I thought I'd get an electrician to check it and if it's OK simply replace the sockets and switches. But there's that nagging doubt...will the cable have aged, is the lighting circuit ok in its original conduit and is it OK to have sockets skirting mounted?
Any thoughts appreciated...
