- Joined
- 27 Oct 2004
- Messages
- 12
- Reaction score
- 0
- Country
Still can't see any main bonding conductors - hopefully they are inside the CU.SausageEggRollWithKetchup said:here's a better pic (including the actual fuse wire), any comments are much appreciated...
No - you misunderstand - I meant it would be wrong to only do that as a way to fix the installation.Damocles said:Come on BAS, why does everyone have to be so negative? You just said it would be dangerous to fit a modern CU with breakers and a built in RCD instead of fusewire!
and I was worried that all that he wanted to do was to put in a shiny new CU as part of a sprucing up and ignore all the hidden stuff.SausageEggRollWithKetchup said:how much does a reasonably good replacement consumer unit cost nowadays, to replace what i have? bearing in mind that i am decorating and sprucing most things up in order to sell the house next year
ban-all-sheds said:Doing nothing would be a better option than fitting a modern CU and not attending to anything else.
