Posted in error
I could have said a desired room temperature of 21C; though that should have been obvious.Assuming Flow/Return temperatures of 70C/50C and a room temperature of 21C, a radiator will produce only 70% of the BS EN 442 quoted output. This mean that, if you want 1000W output, you will have to install a nominal 1400W radiator.
If you have a room temperature of 21C, why do you want the radiators to give up any heat?! Hot enough!
Nozzle
Bad day at the office sweetheart?
In the time you have over engineered the simplest of jobs I could have fitted the system!!!
= Combi sized to suit hot water forget about heating unless you live in a mansion normal house anything from 28-35kws will be fine
= Any rad valves will be fine you aint on a one pipe system (I hope?!?!)
= Rad sizing is easy Big room big rad small room small rad. You cant really over size if you fit TRVs.
Fire 22mm from the boiler to the middle of where the rads are and spew 10mm to each rad from there. Quite possible to 1st fix an empty stripped house and test it in a day. Plumbing aint big or clever dont over think it.
Saying that if you really want to have a system to be proud of....
Somethings you will need are a low loss header, an Intergash, crimp fittings, 6 pond stats and a 80's alarm clock. With these simple components you can have a system that will run at 150% efficiency.
No. The individual room kW requirement is dependent on the rate of heat loss and the required temperature rise, e.g -1C to 21C =22C rise. If this works out at 1kW then you need rad(s) which produce 1kW. The problem is that a rad output is not a fixed amount, like an electric fire, it varies depending on three temperatures - Flow, Return and Room. British Standard BS EN442 specify the temperature to be used when testing a rad (75C Flow, 65C Return, 20C Room). This means you can safely compare rad outputs from different manufacturers.That is very useful. Does that mean that I should be adding another 30% or so due to loss to whatever the individual room BTU / kw figures are?
