Off my plans for the conversion I am buying...
'Soil stack into 100mm3 rest bend. Vent pipe reduced to 50mm3 after last horizontal connection onto 100mm3 internal soil stack. Vent pipe taken up to tile outlet. External SVP to terminate with wire cage 900mm above any opening light'
This is for an internal stack and I think I understand the first and last bits but not the middle. Does the first sentence simply say that right at the bottom of the stack, where it will exit to the drain it needs a reinforced bend to take the weight of the pipe above??
The last sentence is just referring to capping the pipe as it goes out through the roof??
Is the middle bit saying that above the last connection from the toilet or other waste the pipe diameter can be reduced to 50mm3 and this is the size of pipe that gets vented through the roof??
Regards
D
Regards
D
