No - the problem is that you consider it so unreasonable to assume that if servers were to be virtualised in order to be able to migrate live VMs then the necessary technologies to enable live VM migration would be employed that you've launched into sustained criticism.
You're slowly getting to understand.
Yes, I consider it unreasonable to make a statement that requires a lot of techniques that are
not inherent in the <whatever>, and where common understanding of the technique mentioned would not include those additions, without mentioning it.
You are in a minority of 1, or so it appears, in thinking that virtualisation (in the context you used it) == virtualisation technology + redundant server capacity + shared storage* + relevant shared filesystem/whatever* + management tools*
and that anyone else would immediately think the same. Perhaps in some contexts such a belief would be justified, this is not one of them.
You yourself have admitted that the shared storage*, shared filesystems/whatever*, and management tools* are not an inherent and inseparable part of the technology known as virtualisation. Without them, your statement is false.
Your continued attempts to justify why they should be considered inseparable, or that the only reasonable assumption anyone could make is that they are also used, simply make my initial response seem more and more appropriate.
* Depending on/appropriate to the virtualisation technology in use.
Obligatory (or so it seems these days to keep the troll happy) boilerplate
You've kept introducing various analogies which actually prove my point. Take your introduction of toasters for example. If you mention toaster, then a reasonable image that most people will think of will almost certainly be an electric one - by far the vast majority of toasters are mains electric powered, and that is the type that is used by almost everyone. Thus there is no need to mention needing an electrical supply - that is a
reasonable assumption. However, if your were intending for it to mean a gas powered toaster together with the bottle and regulator etc, then it would be necessary to mention it so as to differentiate what you are talking about from what almost everyone else will think of. That is, unless the context would naturally make the gas power what most people would be thinking of.
Analogy : virtualisation (without any qualification) = toaster (assumed electric), virtualisation (with mention of needing the appropriate infrastructure and tools) = toaster (with mention of being gas powered and need ing a gas supply).
Simply stating (say, in a thread about camping) that "a toaster will toast your bread" would be a ridiculous statement except in limited contexts, as was your statement that "virtualisation
will allow you to do live migration". However, "a toaster will toast your bread while out camping - but you'll need a gas powered one if you don't have an electric supply" would be perfectly valid, as would "virtualisation
may allow you to do live migration (if you have the right infrastructure in place)".
Of course, a big difference is that most people understand toasters - so if you omit details then the majority could probably see what you meant. That is not the case with virtualisation - in a forum discussing electrics, it would be expected that the majority of people aren't virtualisation experts, and would not know the difference between "virtualisation" and "virtualisation" (with the assumptions you expect everyone to make).
