- Joined
- 27 Jan 2008
- Messages
- 25,365
- Reaction score
- 2,982
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
One some times wonder what is an electrician, plumber, pipe fitter, or gas fitter? In my early years most cables I used were steel wire armoured, the odd item was single phase, but most were three phase, a plumber was a worker of lead, a pipe fitter main tool was angle grinder and heavy wall 32" pipes take a lot of skill to ensure fits. And the gas pipes I worked with were 42" and snaked across Algeria.
House bashing as we called it was for young men, as speed was everything, and very little skill required, the central heating wiring was likely the most complex he would find.
New and bulk rewire was mainly following a set plan, some times rather annoying where good equipment was thrown into the skip, but it was boring repeat work, but for an apprentice it allowed them to learn the basics rather well, and because it is repeat work, you will quickly work out what is required. And in the first week you will work with a skilled guy, so can use his tools, and then you can get exactly what is required.
40 years ago chisels and hammers were supplied by the firm, there was a case it seems of a splinter of metal flying off and injuring a fellow worker, tool of low quality injuring the owner is one thing, but some one else was a real problem.
