Hi there
I'm in the process of trying to design and construct an overflow system for our newly obtained 180 litre Tropical Marine tank because drilling a prebuilt glass tank is not something I want to risk!
What I've got so far is below:
View media item 1599
This is my diagram which is based on the below which doesn't quite look right to me...
View media item 1600
Basically the idea is that water overflows from the main tank into the overflow system - which then overflows again into the 10gallon sump underneath. Water is then returned to the main tank via a submersible pump - the pump effectively regulates the flow between the sump and the main tank.
At the moment I'm thinking of using guttering downpipe for the overflow chambers (dk grey in my diag) with 22mm speedfit pipe for the siphon tubes (lt. grey). Alternatively I was thinking of using washing machine outlet pipe for the siphon as it will bend easily over the rim of the tank without kinking - the only problem being the fitting of an air bleeding tap at the top of the siphon.
My questions are as follows
1) can you get stop ends for downpipe - solvent weld is pref as the overflow outside of the tank is going to contain a few litres of water and if the bottom falls out will empty and then by virtue of the siphon will empty the tank.
2) relates to the above - are solvent welded pipes suitable for potable water - or will the 'glue' poison the fish/corals etc.?
3) How tight a bend can you put in 22mm speedfit pipe - I presume you heat it in a bowl of boiling water etc and when floppy bend to shape - is this right and will the pipe stay bent after it's cooled?
Cheers
Richard[/img]
Cheers
Richard[/img]
