Loft water tank - overflow pipe problems.
Firstly thankyou for a decent and very descriptive post!
Once the inlet of the overflow pipe is fully covered with water the siphon should start, if the pipe run is good. The fact that you have to raise the water past this, and submerge it more, suggests that the pipe run is not all it seems.
The siphon is important as it enlarges the effective capacity of the overflow pipe. While the water is partially covering the inlet of the overflow it makes a gurgling noise (which if the overflow pipe falls a long way can be very loud) and acts as a warning to what's going on. If the water can continue to rises to where it covers the inlet completely then it goes quiet but the flow increases markedly. Its flow is then depenedent on the pipe's bore and also vertical fall. For this reason some of the overflows I have fitted, once clearing the building, continue vertically downwards. Some fall by as much as several feet before ending. In small volume tank (like toilet cisterns) this ability to suck is important as there's a lot of systems around with an overflow that cannot take the full flow of the ball valve. Like Agile says turning down the inlet valve can be good but in a cold water tank sometimes you dont want to do that.
The vertical distance from the inlet of the overflow to the top of the tank gives you a buffer between the overflow occuring and the tank overflowing. Where the ball valve is is down to you and its requirements. Usually the ball valve mounting is above the normal working water line of the tank.
Hi Peet, thanks for the post. I have to say as a non-plumber (I work in the IT business) I have found this issue quite fascinating. I do love plumbing; especially when there are wonderfully knowledgeable people like you guys to help me out.
As I said in my OP the 3m x 21.5mm pipe and bent 90-degree tank connector are brand new; the pipe runs dead straight and true with absolutely no bends or kinks (except the 90-degree connector) and certainly no leaks anywhere.
As you say the essence of this problem is understanding how the siphon effect actually works in practice. I have observed the outflow very carefully and it is very sedate at first (accompanied by the gurgling that you mentioned) and gradually increases, but not majorly. Once the overflow pipe is 6.5cm below the waterline the pipe gives a small ‘gurgle’ and the full siphon effect kicks in and the water level drops very rapidly; air then re-enters the pipe and this sedate/full siphon cycle starts all over again.
Logically ( I’m big on logic, but unfortunately not plumbing!) there must be a small bubble/oval air-pocket that sits at the top of the pipe, ‘lurking’ around the 90-degree elbow, that gets slowly squeezed and shifted as the water pressure increases, to a point where its sudden release triggers the ‘full’ siphon effect. I strongly suspect that there must be a ‘tipping-point’ that has a direct correlation with the angle of the overflow pipe (25-degrees in my case). Pity they don’t make ‘transparent’ pipes and connectors then we could watch what is going on inside.
As I said before – all quite fascinating; or maybe I’m just a bit sad and obsessive...probably both!
The idea of reducing the water pressure to the inlet valve doesn’t really appeal as I don’t want to listen to the tank filling up any longer than necessary...especially at night.
To summarize, I think the watchword should be don’t put your overflow outlet too high up the wall of the tank. That is obviously something the original installer of my plumbing didn’t appreciate.
But neither did I...... then again I’m not a plumber!
Regards
PS have a look at this link regarding the definition and ‘correct’ explanation of a siphon.
http://www.guardian.co.uk/science/blog/2010/may/10/dictionary-definition-siphon-wrong
I told you I was a bit sad and obsessive.
If you have an anorak, put it on now! :LOL:
No, you're not sad. It's good to come across somebody who's interested in what's going on. I'm not a plumber either, i'm an electronics engineer. Although I do all of my own plumbing. And a few other select plumbing jobs as specials.
Being in IT, whilst you probably know what the problem is with a one eyed god I just threaten it with a through investigation of its inards, which usually does the trick.
Hmmn. I have a feel for what you're saying there about the pipe not being in full flow until the overflow inlet is submerged by a certain amount.
My guess as to why would be -
Taking your current configuration of overflow as an example. Obviously the overflow configuration is restrictive enough on water flowing down it to give rise to this situation. Given a big enough overflow then the following situation would not exist. But therein lies my concerns about many of the overflows you see in use.
With a rising tank water level and a gentle fall on the pipe, the water enters the overflow and flows down it at a sedate (good word, glad I thought of it ;) ) rate. Both water and air enters the top of the pipe, trickles down it and out of the end.
The tank level rises a bit more to where the overflow inlet is nearly covered (perhaps just over to the top of it?). The flow down the pipe is still at a rate that's less than it's fully capable of. It now starts to make a noise as it sucks air with it. I'll guess that what's happening at this point is that the falling water going down the pipe, whilst sometimes making a seal at the top, due to the suction, occasionally breaks that seal in the easiest way it can. The pipe is a mixture of air and water and complicated by the fact that the air wants to rise and water wants to fall.
The tank level rises even more to the point where there is enough water pressure at the inlet for the water flow to flush the remaining air out of the overflow pipe. At some point, and it's easily seen in small bore pipes with air bubbles in them, flow wins. I have no idea what the equation would be (where are the fluid dynamics people when you need them?). Now the pipe is fully loaded with water. Here positive feedback kicks in, the fully water loaded pipe then increases in flow up a rate determined by pipe resistance, head of water at the inlet and probably a couple of others. The higher flow allows the pipe to suck the tank to a lower level than the full flow could ever start at. The cycle repeats.
They don't specifically but you can make them. One of my first posts to this group was about the problems and cure of a central heating system. Many people had had a go at trying to establish what was wrong with a friend's system. There were all kinds of effects going on: Pump cavitation, Hydrogen being produced continuously in one particular radiator, periodic noises, corrosion, magnetite buildup in select pipes, poor heat flow, motorised valve ball had rotted through, kettling in the boiler. In the end I made some clear plastic sight glasses (basically transparent pipes) to go inline with some of the 22mm copper pipes and built some visual pressure gauges (lengths of vertical clear pipe tapped into the system in and around the pump so I could see in real time the effects of flow and the pump) from polythene pipe. The result was a revelation and allowed me to see changes in pressure and also the fact that it was virtually blocked in one particular place and that there was a constant ingress of fresh water into the system from other problematic plumbing. It let me properly see what was going on rather than blindly replacing components/piping and not learning much from it.
I've been fortunate enough at times to have had the time to investigate some of this and learn from it, although my friend nearly throttled me on about day 4. They did get a fully fixed system. In the unknown there's usually something to be learned.
I often find myself wanting to joint different systems together, and between what the plumbers merchants have or know about and what the Pneumatics/Hydraulics people have and/or know about. Thankfully they both cross in British standard pipe thread (BSP)! Although trying to describe what you want when you're not sure of the name for it without going into why you want it (as that usually causes far too many questions) can be hard work.
The link is most amusing. I never realised that the OED had that wrong. Mind you it's not the first place I'd look for that kind of info. I never attributed the workings of a siphon to air pressure.
The tank level rises even more to the point where there is enough water pressure at the inlet for the water flow to flush the remaining air out of the overflow pipe. At some point, and it's easily seen in small bore pipes with air bubbles in them, flow wins. .
Hi Peet, I'm still wearing my anorak. :) Thanks for the post - very informative; your description of the battle between descending water and ascending air-bubbles wins it for me.
Now that between us (you, me and John 'Burnerman'), we have solved the ancient and vexing problem of of how water flows down a plastic pipe, should we turn our attentions to the Economy ?
......... oh dear, medication time.
Regards
