Are acro props easy and safe to use?
20 Jan 2013
London
Seriously folks - Do you just jack it up and away you go?
Is there any chance of the first floor caving in when using them?
Can I ask BC to inspect the acro props before I remove a load bearing wall?
Acros can become loose if the ground gives a little.
Acro top and bottom plates sometimes need securing, hence the holes in the plates.
Only if you have put this on the building notice or plans and paid the prop check fee
The BCO can also check your car oil and tyre pressures while he is there
