No, but it's not a car.
If it's a case of "it's still hanging on the wall - radiators are hot - warm water coming out of the taps - it's ok..." then I can do that. I'm quite a big fan of "If it ain't broke - don't fix it"
I guess what I am trying to determine is what exactly are they going to do when they "service" it?
Does anything require lubricating?
A proper service (dependant on make and model) will consist of
changing seals as reqd, checking combustion co/co2 ratio, checking working and burner pressure where applicable, gas rate, clean siphon/trap, clean heat exchanger, check ignition system and flame failure device, check for leaks, check expansion vessel pressure, check operation of pressure relief valve, checking flueing and ventilation etc etc. A boiler that has not been serviced at the reqd intervals invalidates the warranty (same with cars) and
some models if neglected have been known to catch fire! You have been warned. . . . . .
