Good afternoon All,
I was hoping to get some advice regarding a 2 up 2 down property was partly rewired about 8 years ago by the previous owner, the downstairs wiring and all sockets were done, although the CU was not changed there is an old Wylex with MCB's in.
The is an earth bond on the incoming gas supply which is also bonded to the water mains and then to the CU and lastly to the suppliers fuse. Using a calibrated Robin 4120DL set on the loop impedance function I have taken reading at all sockets and they are between 0.22 ohms and 0.38 on the 20ohm range.
Are these acceptable readings and within regulations or do I need to do other tests?
kind regards
James.
kind regards
James.
