The Primary heat exchanger transfers heat from the hot flue gases to the primary water, which is pumped to either the radiators or the secondary heat exchanger depending on the position of the diverter valve.
The Secondary heat exchanger transfers heet from the primary water to the secondary water, the hot water supply that comes out of your taps.
