Ariston AWD12 Advantage
Margeritha 2000
Serial No: 407023834 *80260960030
Hello to the forum!
This is my first post and have tried to see if my problem is repeated elsewhere on the forum, however no luck.
My Washer dryer seems to constantly fill with water and drains also. The drum turns but the water constantly fills and fills.
If I try to turn the dial to another setting it will just decide to turn constantly until it reaches the the place it was before prior to moving.
I have checked and cleaned out the filter and it wasn't really dirty anyway.
When I have selected a spin mode, the drum also fills with water and appears to be filling only from the pre wash section of the powder compartment.
The water pipes, both hot and cold have been fitted correctly and the waste pipe has also been fitted/placed correctly.
I had the top cover of (Isolated from mains firstly) and was thinking it could be the water solenoid inlet valves (looks like a set of 3 combined) or maybe the water pressure switch?
If it was the solenoid is it possible just to replace the coil part or will it need the whole solenoid unit?
I have a multi meter but I am unsure what to do next to try to get to the bottom of this problem and get this problem fixed.
Other than that I never use the drier and the machine is in really good condition, unfortunately I cannot afford to purchase a new one.
I would really really appreciate any help please. I'm usually quite good and electrical/mechanical repairs but on this occasion I'd rather take good advice from this forum firstly.
Many many thanks.
Margeritha 2000
Hello to the forum!
Many many thanks.
