Ariston MicroGenius 27 DHW Problem
The Microgenus is quite a reliable combi - but sludge can kill any combi.
Oh dear
Everything was working fine last night but this morning I'm getting the red light showing on the boiler which appears to be overheating problems :cry:
Just a thought, there is a small wire in the centre with a plastic sleeved connection which gets in the way when removing parts and can get slightly disconnected which would give you your problem and that light, check to make sure the two spade connections are tight.
Thanks for the tip waterworks, tried that but to no avail :(
Dunno if this is related to the red light problem but whenever I turn off the DHW sink tap I get a shuddering noise from the boiler :(
