i have run some armoured cable 3 core to my shed from the fusebox and have a second hand fusebox at the shed end. i have a joint in the middle which is in a plastic outside juntion box (about 1 foot sq) i will be connecting some outside lights to it later.
my question is how do you connect the gland rings together that earth the protective wire and do i connect the rings to the eath circuit at the meter ends.
i have the wires wired up ok. i.e. live/neutral/earth.
