Arnold Shortzenegger
25 Jan 2004
Here is an interesting yet random fact: Arnold Schwarzenegger is insecure about his height! This came up when I was reading this. Apparently you are more likely to win a US Presidential campain if you are taller than the other guy.
So I looked into it a bit on the net, and it turns out that Arny is in fact somewhere between 5'8 and 5'10. This came up when he was running for Governor, and he refused to be measured to prove otherwise! He allegedly wears built-up shoes, hence why he is usually to be seen wearing cowboy boots (hides the "lifts"). In fact, the US press appear to regard Arny's heigh as something of a running joke!
So if you are feeling a bit insecure, provided you are 5'8 or taller you can now be safe in the knowledge that you are taller than Arnold Schwarzenegger. :D
Height didn't do Kerry much good.
Have you noticed how the shorter you are, the more your muscles bunch up? Must be good in some line of work.
