Asbestos undercloak
22 Jun 2024
Following a survey we have been told we may have an asbestos undercloak on our roof verge. We need the pointing repaired which I think is right next to it. The survey said ‘low risk’ but remove if doing building work. I guess this is building work right next to it. Should it affect the works? Thanks.
Asbestos has been flagged as low risk. Means don't go sanding or damaging to create dust...
Avoid disturbing where possible.
My local tip takes asbestos if I was to register on the council website, so you maybe able to dump it for a small charge if you have that facility?
Ask contractors if they are happy to remove then decide if your going to put back or replace it with something less hazardous.
Go look at the HSE website. What you need to know will be there.
Just so much of it around there isn't a hole big enough to dump it. Just have to manage the low risk stuff. I got rid of all mine on our property
