I'm just back from having my regular iron IV top up in hospital - make of this what you will.
This was my third or fourth regular session, and slightly different than the usual method in that it was a syringe injection, straight into a vein, rather than a bag of fluid gradually dripped in. The explanation for the difference being that they had got me to the level I needed with the bulk IV, no it was just a small 'top up' to maintain my level.
Process was a needle into a vein on the inside of my elbow, replaced with a flexible tube or very thin pipe, draw some blood out into the clear tube, flush through with water, then the iron goes in slowly over a couple of minutes manually, via a syringe.
Issue is that my kidneys are not producing enough iron and iron in the blood is what carries the oxygen to the muscles etc. around the body. As my iron levels decline, my stamina disappears.
I am not sure quite how quickly my body should respond to the IV, but the impression I get is that it works almost instantly.
