- Joined
- 27 Nov 2016
- Messages
- 21
- Reaction score
- 0
- Country
I have a number of projects I want to do in our new (old!) house. I think I understand what's notifiable but would appreciate confirmation/input to make sure I don't run into trouble.
1. External sockets in garden. Spur taken off kitchen ring circuit to an RCD/13A-fused faceplate inside, then from that to an external IP67 junction box, socket, and an armoured cable to another socket further down the garden. As far as I can determine, this is not notifiable since 2013 in England.
2. External socket, at front of house. The least messy way here (the room's decorated) is to simply wire the external socket to an internal RCD/13A-fused plug with 13A flex, and plug it into a nearby socket when required. There's a perfect, existing hole though the wall I can use (old aerial cable route).
3. Fireplace lighting. In a non-functional flu! Fit a spur socket inside the flu above the fireplace 'hole', from the ring-circuit socket on the other side of the chimney breast. Into that would be plugged some red 'fairy' lights in a mock fireplace.
4. Loft power for TV amp and a network switch. Spur off upper floor ring circuit and take the cable up through the airing cupboard in the bathroom, to a socket in the loft. Optionally put in a FCU in the loft to feed two sockets at either end of the loft. From reading here, I can do that in the airing cupboard because that's not considered to be in a special zone.
5. Socket and LED lighting in dressing room - to make the misses happy. Take a spur from the ring circuit (which is on the other side of the room) to give her a socket under the dressing table. From that, either just plug in the PSU for the LEDs, or use a FCU and hard-wire the PSU (and mains socket next to it) at the end of the spur. The LEDs are fixed into a cupboard (the over-the-stairs cupboard) next to the dressing table, with an inline switch on the mains wire to the PSU.
I don't think any of that is notifiable from what I've read... can anyone tell me different?
